Copying meeting link to power point presentation | Community
  • August 18, 2022
  • 42 views
I have recorded a meeting and I am trying to copy the link to a power point presentation for my professor to open. I have copied the link but the link is not able to be opened. Is there a way to fix this problem?
Thank you!
    ZoomTestKitchen
    Specialist
    Specialist
    September 2, 2022
    There are several reason why this might not be working. Not quite sure what's not working and what message or results you're actually seeing. But, I'll give it a shot...
    1. Go to Recordings in the Zoom Web Portal and click on Share on the recording you wish to make available.
    2. Then click on the Share Settings button to set the options to your desire. Click Save.
    3. The select the option you want under Who Can View.
    4. Finally click the Copy button to copy the URL to the clipboard.
    5. Then you can go to PowerPoint, select Insert Link, paste the URL into the Address field.
    6. In PowerPoint edit mode you can press Shift-MouseClick to test the link, or go to Presentation Mode and click on the link.
