Connection Issues | Community
Connection Issues
  • October 19, 2021
  • 4 replies
  • 49 views
Hi everyone,  I'm unable to connect to zoom meetings
Error message: Check to make sure you're connected to a stable network that is not blocked by a firewall or proxy. I am facing issues while connecting to the Zoom client on my MAC. How do you fix this problem, please?
For the past two weeks, I'm not able to connect to zoom using my mac.
    Participant
    October 19, 2021
    Hi, and thanks for reaching out to the community.
    Have you checked your wifi connection yet? If so, have you made sure that both your software and zoom application are up to date?
    I have exactly the same problem with my Macbook.  Wifi is perfectly fine, no firewall or proxy.  The O.S is updated (macOS Monterey 12.1).  I uninstalled and reinstalled version 5.9.1 but nothing seems to fix the problem.
     If anyone has any idea what can I do to solve the problem, I appreciate it.
    Participant
    January 3, 2022
    Then I would recommend contacting Zoom Support.
    You can do that by visiting https://support.zoom.us/requests/new
    i have the same issue, but i can connect from the browser.
    Zoom Version: 5.11.11 (10514)
    Mac 12.6
