laulau11
Aug 13, 2021 8:02 AM UTC
Connection issues
My WiFi has never been an issue before and now I cannot log into my account saying my connection is failing? I’ve tried to fix it multiple times and it still won’t work
    EDPK
    Aug 13, 2021 8:27 AM UTC
    Can you see any error messages or popup windows while log in? Can you share screenshots of the issue?
    laulau11
    laulau11Author
    Aug 13, 2021 8:34 AM UTC
    EDPK
    Aug 13, 2021 8:39 AM UTC
    Seems to have your network has some issues. Can you access Google or any other Web access with your device? Please check this article: https://support.zoom.us/hc/en-us/articles/201362463-Wireless-WiFi-Connection-Issues
    Cheers!
    Aug 13, 2021 11:56 PM UTC
    Me too. Suddenly I can’t connect.
    Dec 8, 2021 3:04 AM UTC
    I had a similar issue with one of my users. The solution was to click on the drop down arrow next to the Zoom icon at the top of the app. There's an option to connect to zoomgov.com. Select this and login. It should fail. Then go back and select zoom.us (default) and login. It should work.
