New Member
Oct 25, 2026 8:46 AM UTC
connecting problem
I am using Zoom Workplace 7.2.1 (43844) on an HONOR Pad 9 with MagicOS 8.0 and Android 14.
Every time I start or join a meeting, the app returns to the previous screen at “Preparing meeting.” This happens on both Wi-Fi and mobile hotspot.
Clearing the app data temporarily fixes the issue, but it returns after some time. Reinstalling Zoom did not solve it.
Has anyone experienced this issue on HONOR tablets, and is there a known fix?
    TrishGallardo
    Oct 26, 2026 8:40 AM UTC
    Hi ​@Teslime Emin,
    Thank you for reaching out.
    There's no confirmed, HONOR Pad 9–specific fix for this exact "Preparing meeting" loop at this time.
    That said, there are several troubleshooting steps worth trying while a permanent fix is pending:
    Troubleshooting Steps to Try
    1️⃣ Update the Zoom app — Check Google Play for a Zoom update and install the latest available version, since Zoom recommends always using the newest mobile app release
    2️⃣ Check HONOR's app and battery controls — In Settings, search for App launch (or Launch), find Zoom, and set it to Don't allow if that option exists. This addresses HONOR's documented background-restriction behavior for apps, and while it's not a confirmed fix for this specific join failure, it's worth testing
    3️⃣ Temporarily disable VPN, private DNS, or ad-blocking/filtering apps, then attempt to join again. Also verify that Zoom has microphone and camera permissions granted.
    4️⃣ Try joining through a browser or another device to help isolate whether the problem is specific to the HONOR Pad 9 app installation rather than the meeting itself. Zoom's troubleshooting guidance also recommends this as a way to test an alternate join method
    Recommended Next Step: Submit a Problem Report
    Since reinstalling and clearing data haven't produced a lasting fix, the best path forward is to send Zoom Support a problem report with app logs, including:
    • The exact Zoom app version (7.2.1, build 43844) 5
    • The HONOR Pad 9 model 5
    • MagicOS and Android version details (MagicOS 8.0, Android 14) 5
    • A note that clearing app data only provides temporary relief 5
    I hope this helps.
    New Member
    Oct 26, 2026 10:18 AM UTC
    Hello Zoom Support,
    Thank you for your response.
    I have already tried reinstalling Zoom, but the issue persists.
    Here are some additional details about the problem:
    - Device: HONOR Pad 9
    - Operating system: Android 14
    - MagicOS: 8.0
    - Zoom version: 7.2.1 (build 43844)
    Zoom sometimes works immediately after I clear the app's data, but the problem returns after a few successful attempts. Clearing the cache alone does not resolve the issue.
    In some cases, Zoom starts opening a meeting, but when I tap the camera button, the app closes unexpectedly. In other cases, I cannot start or join a meeting until I clear the app's data again.
    This appears to be a recurring issue rather than a one-time installation problem.
    Could you please escalate this case to your technical team and investigate a possible compatibility issue with the HONOR Pad 9 running MagicOS 8.0 and Android 14?
    Please also let me know how I can submit the relevant app logs and whether there is a known issue with this device or software combination.
    Thank you for your help.
    Best regards
    New Member
    Oct 26, 2026 12:25 PM UTC
    I have encountered the same issue on Honor Pad 10
    Even after Resetting the tablet to factory default
    Nor applied all recommendations you mentioned
    So who's on top of that case from your support team ​@Support Team
    TrishGallardo
    Oct 26, 2026 2:33 PM UTC
    How to Submit a Ticket
    • Click Sign In in the top-right corner to access your account and support options.
    • If you need immediate automated help or guidance, you can also use the Zoom Virtual Agent icon located in the bottom-right corner of the support page.
    • Depending on your plan tier (Basic, Pro, Business, or Enterprise), you will be routed to available support options such as web ticketing, chat, or phone support.
    New Member
    Oct 27, 2026 8:09 AM UTC
    Hi there. I just encounter the same issue with you for the same model.
    Hope it will resolve soon. Really need to use it here.
    New Member
    Nov 3, 2026 7:29 AM UTC
    I have the same promble also
