Changing "Stay signed in" checkbox default to NOT "Stay signed in" . | Community
When you sign in the "Stay signed in" checkbox is automatically checked by default. How can I change this so that is is NOT checked by default?
Hi BigBlue - welcome to the Zoom Community.
To my knowledge, there's no way to adjust this. The "Stay signed in" box is automatically checked because Zoom's default design is to keep you logged in for convenience. It's meant to save you the hassle of entering your password every time you use the app or the web portal.
Since you can't change the default, your best option is to simply manually uncheck the box every time you sign in. I know that's an extra step, but it's the only way to make sure your session isn't saved. While account administrators for business or enterprise plans can set a session duration to automatically log out all users after a certain amount of time, this is an admin-level setting for the entire account and won't change the default behavior of the checkbox for you.
Same question
