Can NOT be heard in zoom meetings. I hear them , they CAN NOT hear me | Community
  • May 19, 2023
  • 35 views
I Can NOT be heard in zoom meetings. I hear them , they CAN NOT hear me
EVERYTHING BELOW HAS BEEN CHECKED .
AND IS IN ORFER.
But  I still Can Not be heard in Zoom meetings.
I hear then, they Can Not hear me "
Please Advise
John
Everything below has been checked and is in order.
Yet I can still NOT be heard in zoom meetings?
Check privacy settings
  1. Click the Windows Start menu, then click the Settings gear icon
    The Settings window will appear.
  2. Click Privacy.
  3. Under App permissions, click Microphones.
  4. Make sure the slider under Allow apps to access your microphone is enabled.
  5. Scroll down further and enable the Allow desktop apps to access the microphone option.
    Hi @John33 welcome to the community! Ill do my best to troubleshoot with you in attempt to get participants hearing you!
    First, can you share with me what Zoom version you are currently running? As well as what operating system you are running Zoom on whether that be Windows 10/11 or macOS (version)?
    I see you took the steps for windows on allowing access to your microphone. Have you attempted to Test audio before Zoom Meetings? And do you have options as to microphone inputs? Suggest choosing a microphone option that recognizes input when testing.
