Camera Upside Down and no volume | Community
Participant
November 10, 2021
  • November 10, 2021
  • 20 replies
  • 189 views
HI, I am new to Zoom and have a meeting tonight. I did a test run signing in today and noticed that the video/camera has me showing upside down and there is no volume even though it is unmuted?
Zoom help said to click on Profile photo at top right hand of page and select settings, when I do this there is no option for settings??!!!
Can anyone kindly help?
    Best answer by Fi33_2
    Ok, that means it has never been updated so there is no older driver to roll back to. If you go this site https://www.asusdriversdownload.com/asus-drivers/asus-x70e-notebook there are two different camera manufacturer drivers list for Windows Vista 32 bit. You can try install both, the one that does not match your camera will just error out during install and should not cause any issues. If this does not fix the problem I would suggest purchasing either a cheap USB camera to use or a new laptop (please go this route as Vista is no longer supported and severely vulnerable OS because of it).
    Hi Chris, you have been a star!!! at least I know now the issue is with my laptop and not a Zoom issue.
    YES, a new laptop is needed, I was sold a real duff!!! I'll try and do Zoom tonight on my mobile.
    Thanks so much for your help, much appreciated : )
    ChrisO
    Specialist
    Specialist
    November 10, 2021
    Are you clicking on your profile pic in the APP on in the web portal?
    Fi33_2Author
    Participant
    November 10, 2021
    HI Chris, not very clued up on computer terminology so bare with me. I am using a laptop I logged onto Zoom using Firefox and went to top right hand corner where it says profile and clicked on it, the only option it gave me was to sign out, there was no settings option?
    ChrisO
    Specialist
    Specialist
    November 10, 2021
    Ah, yeah you are using a browser-based version (web portal) versus the Zoom App, and the instructions they gave you were for the APP. Are you using the built in camera on your laptop or a USB camera?
    ChrisO
    Specialist
    Specialist
    November 10, 2021
    Does your camera appear upside down in any other applications? Hangouts, Teams, the built-in camera App, etc.
    Fi33_2Author
    Participant
    November 10, 2021
    Haven't got any applications that I'm aware of, how can I test this?
    ChrisO
    Specialist
    Specialist
    November 10, 2021
    Windows 10 has a built-in camera app you can simply search "camera" in the taskbar search area and it should appear. I would suggest that you start with making sure your Camera driver is up to date.
    Right-click on the start menu.
    Select "Device Manager" from the list
    Find your "Integrated Camera" in the list of devices.
    Right-click the camera and select "Update Driver"
    In the pop-up window select "Search automatically for drivers"
    there is two distinct camera maker drivers list for Windows Vista 32 digit. You can attempt to introduce both, the one that doesn't match your camera will only blunder out during introduce and shouldn't create any issues. In the event that this doesn't fix the issue I would recommend buying either a modest USB camera to utilize or another PC (if it's not too much trouble, go this course as Vista is not generally upheld and seriously weak OS as a result of it).
    Article Source - https://coverjunction.com/how-to-fix-a-power-surge-on-usb-port/
