Camera flickering | Community
Camera flickering
  • December 23, 2022
  • 55 replies
  • 723 views
Hi
i downloaded the newest Version of zoom yesterday and since then have had issues with the camera when on zoom. This is the case for multiple cameras - it sticks and flickers and the only thing I can do is turn it off and on yet it does the same after a few moments so the process is repeated.  It flickers and goes bright and crazy! I have never had a problem like this before.
I have the same problem on multiple browsers on my laptop.
I have the same issue on different cameras on the same device.
My camera works on Skype and Facebook video call but not zoom.
i have checked the flicker frequency on zoom and it is 50 hz.
What has happened and can you offer any advice please?
Thank you!
    Best answer by Bobbyk1227
    Hi All! I have been informed that version 5.13.5, which was release just now, should resolve the video glitches observed in the previous releases. Hope this helps!
    I am also having the same issue! im not understanding why tech suport isn't available?
    turning off the de-noise in the advanced video features has also worked so far. worth a try
    Do you mean turn off "optimise video quality with denoise"?
    Oh no. Is yours since an update? I really don’t know what to do.
    Yes!! I downloaded an older Verizon and so far it’s working!
    How did you find an older version? I deleted mine after I upgraded (lesson learned).  It happens on client 5.13 and 5.13.3  - haven't seen a fix yet
    Oh wow! Thanks for the advice. I will give it a go.
    Partner
    December 24, 2022
    Hi Zoom Support! I am helping @beanburger199 on this issue. They are using Zoom Version 5.13.0.11216 for Windows.
    We are going to try to uninstall and re-install Zoom again hoping that a clean install will help.
    If that does not resolve the issue, I see references to downgrade to a previous version (e.g., November 28, 2022 version 5.12.9 (10650)); but, how do we go about doing this again? I can't seem to find an option from the Download Center
    Thanks for any help!
    I downloaded the older version 5.12.9 and it works great hopefully there will be a patch to fix it soon
    Partner
    December 24, 2022
    Brilliant @Thall1988 ! I found the download here:  https://zoom.us/client/5.12.9.10650/ZoomInstallerFull.exe. Cheers and happy holidays!!
    Thank you so much Bobbyk1227!  I was trying all sorts of things and delving into HP unknown territory settings and it was an issue with Zoom download!  I missed teaching an online class due to the issue.  On the plus side though I thought it was my laptop camera and some kindly gave me a webcam!  Anyway with your help and the new webcam I've never looked so shiny and new!  Thanks loads
    Exact same issue after 5.13 update on 2 different win10 laptops.
    wow! I have the exact same problem with newest version of zoom.
    thanks for this information. i have downgraded to 5.12.9 and now working fine!
    much appreciated.
    now, i want to know when i can upgrade to the current version 😛
    Same issue with flickering.  Will download the older version.  Thank you
    Having the same issue. Its Jan 2023. I host several meetings and i guess i will have to downgrade to the older version also. Zoom, please get a patch for this. Its very annoying
