Mar 7, 2022 2:26 PM UTC
Camera and mic not working only in Zoom
Greetings all,
I recently downloaded Zoom for my laptop and can't get myself ready for meetings. More specifically, I'm unable to get my camera and USB mic to work, even though I've been using these without incident on Teams and other conferencing platforms.
For instance, if I go to video settings, my camera's light is turned on, but the preview is just a black screen. Accessing these settings causes the Zoom client to hang - forcing me to choose to end task - yet my camera's light stays on, and I have to disable and re-enable the camera app from Windows settings to reset the camera.
On the audio side of things, the speakers' test works fine, but not the mics'. Testing both the built-in and USB mic yields nothing.
I tried the solutions found in Zoom's knowledge base. I uninstalled and reinstalled the client, updated Windows, drivers, restarted my laptop,  and checked the relevant permissions, to no avail. I'm running Windows 10 on an HP Probook. Looking forward to your suggestions!
    Ali_ShAnswer
    Mar 10, 2022 1:04 PM UTC
    Greetings,
    I managed to solve the problem by upgrading to Windows 11. Just wanted to leave this here in case someone comes across this thread.
    Mar 7, 2022 4:41 PM UTC
    Hi @Ali_Sh ,
    Thank you for using Zoom Community!
    Since you have done most of the troubleshooting, reinstalling the Zoom client, system driver and tested the integrated mic as well as the USB mic.
    I would like to confirm on the permissions that you mentioned; for the camera (after doing the drivers install),
    you could also check your privacy settings,
    Windows has specific privacy settings that prevent software and hardware from accessing your camera. That could be one of the reasons why your camera is not working on Zoom.
    1. Launch the Settings app and navigate to Privacy.
    2. Then, under App Permissions, click on Camera.
    3. There’s an option there that says Allow apps to access your camera. Toggle it on
    4. Navigate to Allow desktop apps to access your camera.
    5. Then turn this option on to allow Zoom to access and use your camera.
    As for the microphone, were you able to do the following steps:
    • Use the Windows search box to navigate to Microphone privacy settings. Switch on the Allow apps to access your microphone toggle, and enable access for Zoom
    I hope that helps.
    Aug 8, 2023 4:47 AM UTC
    Hi Zoom employee
    I am using a webcam on my laptop.
    The video is not working on the desktop application. Please help me resolve it
    Ali_ShAuthor
    Mar 8, 2022 6:42 AM UTC
    Hello @Saif_Elmejrab,
    Thank you for your reply.
    I already checked these permissions, as Zoom's knowledge base recommends doing so. Unfortunately, it didn't yield anything. Forgive me for reiterating, but I'm only facing these issues with Zoom.
    Ali_ShAuthorAnswer
    Greetings,
    Mar 14, 2022 4:22 PM UTC
    Hi @Ali_Sh
    Thank you for updating us on this.
    I needed to reinstall windows and replicate the issue.
    However, with what you mentioned, upgrading to Windows 11 solved the issue is quite weird, there may have been an issue with the operating system itself
    Ali_ShAuthor
    Mar 15, 2022 7:25 AM UTC
    Hi @Saif_Elmejrab
    It's worth mentioning that a colleague of mine has been facing the same issue on his Windows 10 machine. Since upgrading to Windows 11 isn't an option for him, I did some troubleshooting for him. The workaround at which we arrived is to have him join Meetings using Edge. It's been working flawlessly.
    Best regards,
    Ali
    Mar 21, 2022 6:33 PM UTC
    Hi @Ali_Sh
    Thanks for the update on this.
    We'll look into this.
    Aug 2, 2022 8:30 PM UTC
    What is the workaround for Windows 10 as unable to upgrade to Windows 11
    Aug 19, 2022 4:37 PM UTC
    I'm seeing a similar issue and would like more info as well. In my scenario, I'm getting no audio when using a Plantronics headset - I've tried both the Plantronics Voyager Legend and Voyager 5200. I can see video, just no audio (can't hear and they can't hear me). Zoom tests fail as well - no sound and no mic.
    Oct 4, 2022 9:31 AM UTC
    Hi Everyone. My colleague's Laptop has the exact same issue. No video and mic can be used when she signs in with the Zoom desktop client in Win10. We do not have option to upgrade to Win11 due to work requirements. Would also be interested in a fix for this issue. One note though, her laptop and mine are the same Dell Inspiron. Mine's working fine. But her system doesn't seem to work. This issue stated a few months ago, before that it was working.
    Oct 11, 2022 8:51 AM UTC
    Hi, I am also experiencing this issue. Microphone works in Teams but not Zoom app. On Edge it works fine via Zoom. Upgrading to 11 is not possible. Any ideas?
    Oct 11, 2022 12:58 PM UTC
    Replaced my Bluetooth USB adapter and have been issue free for several weeks now. Here's the link for the BT300 from Polycom - https://www.poly.com/us/en/products/headsets/accessories/bt300. Check to be sure this is the one you need before ordering, but worked for me. Good luck!
