Cam won’t work
Cam won’t work on the HP zbook. I am using windows 11
CarlaA
Hi @Mic5, thank you for posting for the first time, and welcome to the Zoom Community!
Please update all drivers on your device and then uninstall/reinstall the Zoom app. That should do the trick!
Carla,
Zoom Community Team
Please click Accept as Solution if you found this reply helpful. Thank you!
