C++ Zoom Bot Not Using Specified Display Name When Auto-Joining | Community
  • June 23, 2025
  • 45 views
Hello Zoom Community,
I am building a C++ application that:
  1. Automatically joins scheduled Zoom meetings (using the Zoom C++ SDK).
  2. Acts as an in-meeting speech translator, capturing audio, translating in real time, and playing back the translated speech.
🛠️ What I’m Trying to Do
  • Programmatically join a meeting with a pre-defined display name (e.g. “MyBotTranslator”).
  • Once joined, immediately start the translation workflow without any manual intervention.
🚨 The Problem
  • Although I pass the correct display name to the SDK’s joinMeetingWithParams call, Zoom still pops up the “Enter your name” dialog instead of using my name.
  • Because the name-entry window can’t be controlled by code, the join process never proceeds automatically.
🔍 What I’ve Tried
  • Verified the name parameter is correctly set when calling the SDK.
  • Tested both JWT and OAuth authentication flows.
  • Compared against Zoom’s C++ sample apps (which only work when you manually type a name).
  • Searched the SDK docs for flags or config options to suppress the name prompt.
🤔 🤔 Expected vs. Actual
  • Expected: Bot joins instantly with the given display name, then begins translating.
  • Actual: Zoom stops and waits for manual name entry in the UI dialog.
You may want to bring this to the Zoom Developers Forum instead of this group as it pertains more to general Zoom Marketplace App issues.
The developer forums can be found at:
https://devforum.zoom.us/
