buzzing sound | Community
buzzing sound
  • September 27, 2021
  • 16 views
When sharing the iPad screen with usb c type wired connection, the buzzing sound is repeated. The same is true of resetting the iPad. The same goes for other computers.
https://www.google.com/search?q=zoom+ipad+share+buzzing&rlz=1C5CHFA_enKR970KR970&biw=1920&bih=859&ei=nXNRYareBNGB-AbOrq_oBw&oq=zoom+ipad+share+buzzing&gs_lcp==5
There are many people suffering from this issue, but is there no solution yet?
    Rupert
    What are you connecting to the iPad with the USB-C cable - are you going from a computer to the iPad - with one single cable? If so, what type of computer?
    What type connection for the USB-C cable have on the other end - and is this an Apple-braded cable?
