Blurred Background Problem | Community
  • October 1, 2021
  • 3 replies
  • 30 views
I have Zoom on my PC version 5.8.0 and I want a blurred background but when I go into my settings page under "Backgrounds & Filters", I only have San Francisco, Earth, and Grass. I don't have a Blur option. I have researched this and tried everything and it didn't work. I even uninstalled Zoom and reinstalled it, signed in, went back into the background page and it still doesn't show the Blur option. It says I need to have version 5.5.0 and later. Can someone help?
    Rupert
    Does your PC hardware meet the system requirements for blurred background?
    Supported processors
    Intel i3 - 2 cores or higher - 5th generation or higher
    Intel i5 - 2 cores or higher - 3rd generation or higher
    Intel i7 - 2 cores or higher - 3rd generation or higher
    AMD - 8 logical cores - 3.0Ghz or higher
    Max here
    - Intel(R) Core(TM) i3 CPU 560 @ 3.33GHz
    - Zoom 5.8.4 (1736)
    and blurred background is not available...
    Hi Rupert,
    I have the same problem. Zoom version 5.8.0 and intel i5 dual cores 4th generation.
