Beats Fit Pro bluetooth headphones doesn't work with both audio and microphone
My beats fit pro doesn't work with zoom. I can only choose Beats Stereo audio OR the beats microphone. Otherwise one works and the other doesn't work.
Is this as intended?
    LiriumAnswer
    I had the same problem, but then I went to the microphone icon's options and selected Beats Fit Pro as the default speakers. 🙂
    I have same problem. Did not get much help on Apple support site either
    LiriumAnswer
    My Zoom says I cannot control mic using my Beats Fit Pros. Does anyone know how to fix this?
