Avatar Problem
I have a PROBLEM🤔 🤔. My computer cannot accept the latest update: Avatar😊. It's in beta but it says that my computer dosent support this Avatar😥. I tried to update again, try to find out how to get it,  search and others, but i cannot find out how😫? Can someone help me? Thanks🙏. tips: my computer is Window7.
    DoctorWho
    Participant
    Participant
    January 13, 2023
    Hi @Cookie_bob
    this sounds like you computer don't reach the requirements for this feature.
    According to the support-pages you need the at least the following hardware:
    System requirements for Windows:
    • Windows 7, 8, and 10 or higher (64-bit)
    • Supported processors*
      • Intel: 4th generation or higher i3, i5, i7, i9 processor
      • AMD:
        • Ryzen 3, 5, 7, 9 processor
        • 6 cores or higher, base frequency 3.0Ghz or higher
        • 8 cores
    • A graphics card supporting Direct3D 11
    You can see the processor and graphics in the windows device-manager. If your PC is in the requirements, try to update the graphics driver ;).
    Workaround: Have a look at other tools for Avatars like chromacam or snapcamera.
    Wish you luck!
    Greetings!
