Audio works when I'm a guest, but not when I host
I'm on an iMac with Apple M1 chip running macOS Monterey v 12.1.  I've got Zoom 5.10.0 (5714) for the Apple M1 Chip loaded. Audio settings are "Automatically adjust mic volume" and "suppress background noise>auto".  When I host a meeting I check my mic and speaker and all is working. Yet I can't hear participants and they can't hear me. When I join a meeting as a participant, my audio works just fine. This only happens with 2-3 people/companies I Zoom with. The rest work just fine.
I've rebooted my computer, deleted and reinstalled Zoom. Same problem with these few people.  I also tried it on my laptop (MacBook Pro running macOS Monterey v 12.3 with Zoom v 5.9.1 (3506) for the Intel chip and have the same problem there.
Many thanks for your help!
    IP-Man
    IP-ManAnswer
    @pcarlaw
    You could try a clean removal/uninstall of Zoom Application and then reinstall it again. This is to ensure that any corrupted files/config on the application is all completely removed before reinstalling.
    If you have a Mac -  try uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
    You can do this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
    After this, try to reinstall Zoom again.
    IP-Man
    IP-ManAnswer
    @pcarlaw
    pcarlawAuthor
    Many thanks. Seems to have worked.
    IP-Man
    Glad it worked 🙂
