Dec 2, 2021 12:37 AM UTC
Audio Suppression Not Working
I've set my audio suppression to "high," but everyone can still hear all of my background noise. I have the most up-to-date Zoom version on my desktop. Anyone know what the issues could be? I have a MacBook Air; friends/colleagues with MacBook Pros have no problem with this.
    Dec 8, 2021 9:33 PM UTC
    Hey @tyneejash, the 'original audio' being on maybe causing your noise suppression to be off.
    You can just uncheck the original audio option or in-meeting to ensure that the original sound is off. Let me know if that helps and makes a difference!
    tyneejashAuthor
    Dec 8, 2021 11:24 PM UTC
    Hi! Thanks for the reply! I wish it was that simple, but I did not have that option checked. :o\
    Jun 9, 2022 1:33 PM UTC
    Tyneejash, I just found your post about this issue and am having the same with my MacBook Air. I'm on the latest Zoom Client, the latest OS update, etc. I've reinstalled the Zoom client. Suppression is not working for me whether I'm using the Macbook speakers/microphone or earpods. Did you ever find a solution?
    Jun 13, 2022 7:52 PM UTC
    I have the same problem on MacBook pro, I have noise suppression on high and have tried the work-around suggested. I have zero suppression and it is causing problems with meetings. I never had this issue with teams.
    Jun 23, 2022 10:16 PM UTC
    I had the same problem with noise suppression. It worked like a charm until it didn't.  Here's the solution:
    1. Go to your zoom preferences.
    2. Click on Audio
    3. Uncheck the box for Music and Professional Audio (just below Surpass background noise).
    4. Allow your dog to bark enthusiastically cuz no ones gonna hear him anymore.
    tyneejashAuthor
    Jun 24, 2022 12:58 AM UTC
    Sadly, that box has always been unchecked. Still doesn’t work.
