Sep 29, 2024 11:32 AM UTC
Audio settings
I use Apple Logic Pro for music production. I have a FocusRite audio interface. I would like to play music from that app with high quality audio while sharing my screen and also be able to listen and talk without feedback. What output setting should I use in Zoom? In Logic? What input setting should I use in Zoom? In Logic?
Oct 3, 2024 8:32 AM UTC
careful with using audio output from a DAW. It must be configured for stereo out only - no multi track. Be sure to use headphones connected to the Focusrite instead of speakers. In zoom choose share computer audio from the share > advanced tab. Be sure to select stereo from the drop down menu on the "computer audio" button. Any Focusrite less than a 4i4 is not recommended.
