Feb 21, 2023 12:25 AM UTC
Audio Setting for Zoom Ipad
I am using ipad for ZOOM. Like on laptop, you can see the audio settings for the meeting which tells you which speaker zoom is using and which mic it is using. how do I find that settings for ipad.? I am connecting with an external mic via lightning. audience can hear my voice but I can't hear there voice. Pls advise. Thx
    anissat
    anissatAnswer
    Feb 21, 2023 12:37 AM UTC
    There are no similar settings for the iPad, only because the majority of users aren't typically using additional audio hardware with iPads. It seems that the external mic input that you are using to capture your voice is also routing (and therefore blocking) your speaker output.
    I use a Rode audio adapter which features 2 microphone inputs, and 1 headphone output, and it has worked beautifully. (There are similar adapters that are cheaper.)
    anissat
    anissatAnswer
    ashish531Author
    Feb 21, 2023 12:55 AM UTC
    This worked thanks so much for your help. Thx
