Mar 1, 2022 2:13 AM UTC
Audio Problems (Spotify not working when in Zoom meeting when using wireless earphones)
Hey guys! Can I ask for help? My Spotify music keeps getting cut off (muted) whenever I'm in a zoom meeting and using my wireless earphones. Music and Zoom audio works fine together when using Laptop audio and Wired Earphones, but not on Wireless. Wireless still plays music (Spotify) when using G-meet, but not Zoom. All other sounds get cut off when Zoom Application connects to the wireless earphones. Please help
Details:
Location - Philippines
Account Type -Standard
Audio Source - Wireless Earphones
Laptop & OS - HP Laptop using Windows 10
    _Nyx_Answer
    May 18, 2023 6:42 AM UTC
    okay so I figured out how to fix this since you're using wireless it tends to prioritize Zoom if you get what I mean, so to fix this all you have to do is that while you're in zoom meeting go to your audio settings (the one with the microphone icon and beside is a small arrow press that arrow) then you just have to change your speaker/microphone device to the laptop's speaker (or another device if you have)
    what will happen if you do this is that you will hear zoom in your laptop speaker (or other devices) and you will hear spotify, youtube and etc in your wireless earphones hope this helps! please do update me if it doesn't work
    (the picture shows where you will change the speaker and stuff)
    Nov 27, 2024 8:04 AM UTC
    O Spotify oferece aos usuários os podcasts desejados e os programas em destaque. Ele lhe dá acesso para salvar seus programas e podcasts favoritos, que serão atualizados automaticamente quando o novo episódio chegar. Esses programas e podcasts também podem ser baixados e assistidos off-line. Você também pode controlar a velocidade do vídeo.
