audio problems
Is there some listing of compatible sound cards for zoom? I am troubleshooting a problem with an ASI 5720 sound card that has problems only with zoom, but works perfectly with every other piece of software on the PC. An HP, win10.
Zoom received audio sounds fine but outgoing audio sounds bad, even though it doesn't sound bad at all on other software on the machine at the same time. Recording on adobe audition sounds fine but far end audio on zoom is broken up.
Thanks.
    Rupert
    RupertAnswer
    Hi @Wa2png
    Also, on Windows, in Zoom, you can try the different Signal Processing methods - in Zoom > Settings > Audio > Advanced Button > Signal Processing.
    You can try Raw, Default, or Auto.
    Do make sure you are using Original Audio and Stereo Audio and High Fidelity music mode though, like @Jonathan_H says.
    Make sure to enable these features in Settings and THEN enable Original Audio in your Meeting (top left).
    If you are using a Multi-Channel Professional Audio Interface, and you are sending in audio beyond the first two channels, also be aware that Zoom can sometimes sum all channels together - which may not always produce expected results! But that is an edge case.
    I'd also suggest ensuring you are on the 64-but version of Zoom, to the latest version:
    https://zoom.us/client/5.8.1.1435/ZoomInstaller.exe?archType=x64
    Curious, what kind of microphone is it?
    Have you tried toggling the audio settings for "Music & Professional Audio"?
    Wa2pngAuthor
    Using a pro sound card fed from a broadcast console. I was unaware of the "Music and Professional audio"! Where is it?
    Wa2pngAuthor
    I don't see any check box for high quality music mode. Just ;
    suppress persistant background noise
    suppress intermittant background nois
    echo cancellation
    I have tried toggling all these options and made no difference.
    @Wa2png  - check out Ruperts post below. To my knowledge your description seems to be an older layout of where this option is.
    Make sure you're updated on the latest version, whether it's Windows or Mac. If you're using a managed computer, Windows or Mac you'll need to get administrative rights to upgrade the client. For self updating, try going to the zoom's file menu and "check for updates".
    Rupert
    RupertAnswer
    Hi @Wa2png
    Great points @Rupert, thanks for sharing!
