Audio Problems | Community
Audio Problems
  • June 5, 2023
  • 28 views
For clinical education purposes, I have to say "ah" on recording for at least 10 seconds. However, every time I check my recording, it reduces the volume to where I cannot hear the "ah." I tried the Beta feature for Live performance audio but my account says it in unable to do that. How can I fix this problem?
YaBoiB
Hello @Emilyashton05,
 Do you have an external microphone or headset that you can pair to your laptop/desktop to speak directly into the microphone or are you using a built in microphone? I think that may be part of the issue. Built in microphones do not have great sound quality.
If you have a headset or can purchase one, this might be helpful in performing the task that you are attempting.
Thanks,
Brandon
