Audio Problem when sharing screen | Community
  • August 27, 2021
  • 58 views
After I install the new version of zoom through an update, my audio while sharing the screen becomes problematic
    Hey @LourxG12, for your screen share issue, ensure you 'share computer audio' and 'optimize for video clip' when sharing content.
    Also, within your Zoom desktop client settings under 'Share screen' click on 'Advanced' and check or uncheck, "Use Hardware acceleration to optimize video sharing", and see if that changes or makes a difference for your Screen sharing experience. Along with Checking or Unchecking, 'Use TCP Connection for screen sharing'
    After those suggestions let me know if your screen-sharing experience is better! 😄
    CarlaA
    Hi @LourxG12! If you found @RN52_2's reply helpful, please don't forget to mark it as Accept as Solution 🙂.
    Thanks!
