Audio Problem since round about 3 weeks | Community
  • March 8, 2022
  • 51 views
Hey,
I'm using Zoom for doing interviews. Since round about three weeks there is the following problem:
After my interview partner answered, my next question is (for a few seconds) very low.  After a few words the sound is normal again. But in fact it is very annoying.
What do I have to do? 🙂
Perhaps someone can help me further?
Thank you.
    TomO
        You may want to check to see what your Suppress Background Noise is set at. Go to Zoom Settings in the app then Audio. If it's on Auto try Low and see if it helps. Also try unchecking Automatically adjust microphone if it's checked.
