audio problem | Community
audio problem
  • February 20, 2024
  • 30 views
I'm not able to listen the voice of the host. speakers are working properly but I'm not even be able to hear a  single word from the host. when i use headphones its audible but not audible with computer speaker. what i need to do
February 20, 2024
hi mnadarsh,
check to see that your zoom settings for audio have your computer speaker selected.
click on your profile picture and select Settings
In Settings, click Audio
Hi @mnadarsh welcome to the community! I wanted to put the spotlight on @Eliot's reply and ask if you were able to test your speaker within the Zoom desktop client settings? If you are able to hear the audio feedback after clicking on 'test speaker', you should have no problem in-meeting hearing others. Let us know if this helps! If not, this maybe an issue as to the speaker devices at the device level, more info on Fix sound or audio problems in Windows under "check your speaker output".
