Dec 1, 2021 3:39 AM UTC
Audio Preference volume bar resets to zero
Used to be able to stream audio into zoom (to perform songs at meetings) but now the input volume snaps back to zero when i choose anything but my imac mic as my input...
    Dec 3, 2021 2:42 PM UTC
    Hey @DreBinley, have you updated Zoom to the latest version? Also, do you have 'Automatically Adjust Microphone Volume' unchecked? When unchecked are you able to move the slider manually and does it stick?
    DreBinleyAuthor
    Dec 3, 2021 5:35 PM UTC
    Yes i tried the latest version, as well as the m1 chip version since i have a new mac. yes i unchecked.
    i did discover one scenario that sort of solves this. i can use two audio interfaces one with logic and one with zoom, so i just feed the output of the one to the other. this helps people be able to hear me but unfortunately i cant monitor off either of my own interfaces or my mac headphones in this scenario, which i've never had happen with any other program that i've streamed or met on. and in this scenario the vol bars are still snapping to zero as well. strange stuff 🙂
    Jan 26, 2022 10:02 PM UTC
    This problem began occurring for me sometime within the past few months.  Symptoms are when I join a meeting or are admitted to a meeting from a waiting room, the microphone volume is reset to zero and the "Allow Zoom to adjust the volume automatically" checkbox is ticked.  If I uncheck the checkbox I can move the volume to a louder setting, then I re-check the box and I am OK until I leave and am re-admitted to a meeting.  I am using Ubuntu 20.04 and had been using it without an issue across several Zoom updates for at least a year and a half.  The problem started at a time when I did not make a Zoom update, so I suspect it was an Ubuntu auto-update of some kind (perhaps kernel, maybe a library) that triggered the issue.  I just tried updating to Zoom 5.9.3 and I do not see any change.  It would be great if Zoom engineers could investigate this relatively new issue between Ubuntu 20.04 and Zoom and implement a workaround, if possible.
