May 4, 2023 10:41 PM UTC
Audio/mic cut out partway through meetings
For the past few months, my audio and microphone will work completely fine at the beginning of a meeting but suddenly cut out. Both the audio and mic cut out at the exact same time. This has happened 30 minutes into meetings as well as 3 minutes, so there is no standard time frame. I have already tried to uninstall and reinstall Zoom with no improvement. The same issue happens with and without headphones. Once the audio/mic cut out, they do not come back. I always leave and rejoin the meeting, and they both work fine immediately upon reentering. However, the issue may occur again in the same meeting/link a while later. For reference, this is on my laptop which is a late 2015 MacBook Pro.
    May 5, 2023 2:12 AM UTC
    Zoom support can look at your log files if you want to open a special kind of support ticket
    Here’s how;
    • Sign in to Zoom desktop client.
    • Click your profile picture, then click Settings.
    • Click Statistics
    • Click Send report.
    • Select a product from the Productdrop-down list.
    • Select a problem from the Problemdrop-down list, and specify the date and time that the problem occurred.
    • Under Description, enter a brief description of the issue.
    • Select the check box next to Include log file and system information to send the log files generated by the client to Zoom Support with the problem report.
    • If you already have a support request open, select the check box next to I have a ticket ID, and enter the ticket number.
    • Click Send.
    • https://support.zoom.us/hc/en-us/articles/360037195152-Sending-meeting-or-webinar-problem-report-and-client-logs
    Regards
