Audio issues with musical instruments | Community
  • February 7, 2023
  • 23 replies
  • 170 views
I have been teaching piano/keyboard lesson using Zoom, as well as given many lectures for Yamaha using my digital piano. Last Wednesday and Thursday I was unable to hear my students instruments, and they were unable to hear mine. I would hear about 4 notes, then everything was gone. I could hear them speaking perfectly, but no instruments. I use a Windows 10 computer, and all students were on iOS devices. I pay extra for this service, and don't use the free service. What has changed, and what do I need to do to be able to teach successfully again? This is a real problem. Thank you! Lori
Também estou com problemas de audio e tenho outros dois amigos que utilizam o Zoom que estão com o mesmo problema.
Havia abrigo um ticket para esse problema, mas o suporte do Zoom não conseguiu, se quer, entrar em uma reunião para verificar o problema.
Tentei fazer contato com o Suporte através do telefone 888-799-5926 e o atendimento eletrônico não consegue localizar a minha conta, mesmo fazendo pagamento anual do serviço.
Any chance your response can be translated into English??
I am having this very issue as well. Have you enable Original audio in your account and then also while on "the call"?
Onde encontro essa configuração???
Antes das atualizações feitas pelo Zoom tudo funcionava bem, mas agora se coloco um video do YouTube para passar se eu falo interrompe o audio para os participantes e se algum fala interrompe o audio para todos os participantes.
Sorry you are having problems.  I am having an issue for my fitness class.  My instruction voice heard fine  but they can't hear my music.  I have musician boxes checked from that update.  This is on a Mac Pro.
i am also facing the same problem in zoom. My students can able to hear my voice not my instrument sound. what to do? how to fix?
I am having same problem were you able to resolve this .?
After deactivation of the Realtek-Sound-Enhancement within the Realtek Tool in Windows IT worked for me.
I don't know if you have checked these but the original sound should be selected as well as going into setting enhancements on your computer settings. For me I have a Mac pro, which has no enhancements, so I went to Apple Music and turned on the equalizer after selecting  from the menu.  I selected more treble, but there are more settings.  I also unchecked automatically adjust mic.  We shall see tomorrow.  I already tried with 2 students, who said the sound was better.
Similar problem here. The music in shared videos is deleted automatically, I only can hear voices, no instruments in background and only music is muted completely. Realtek Audio. It seems there are some included filters (windows or zoom) which are wrongly adjusted. I din't find any solution till now...
BB_Churches
We have just started seeing this problem in our zoomed church services.  The spoken word is fine, but the music is just not being picked up.
Hi, Lori!   I just bought a new Acer laptop PC...and it is having the same problem....voice is fine but my string instrument, a harp, will not register for the listeners. My old Acer was just fine with Zoom Audio but it was slow and the video was glitching so I changed to a new one.  I test the microphone on the new one and am having the  same issue as you....I am using Windows 11 but I see that others in Windows 10 are also having the same problem.   I wonder what has changed.   I am so frustrated that I am going to try an external webcam with microphone, camera and speaker to see if that will solve the problem and forget about using the software on the PC.   There must be some reason that all of a sudden Realtek will not support my instrument.... I even went on the chat with the windows people and had them try to fix the problem by uninstalling and reinstalling the realtek software...it still didn't work.   I have tried all the setting audio combinations I can think of ....  I have a few days to return the webcam if it doesn't work.  I'll try to get back to this thread afterwards ......
We are an online piano school experiencing the same problem with music being lost with the audio settings. It seems to vary depending on the device the student is using. It never used to be this way until the most recent update. Zoom PLEASE fix this! Some of our livelihoods depend on this.
In addition to ensuring that original sound is enabled in your settings AND while you’re on each zoom session (typically upper left hand corner), check to see if your Windows 10 device has an app called Bang & Olufsen. It is an audio control app. In the noise cancellation tab, ensure that noise removal to input and output device are off. This fixed it for me
Thanks for the tip! Any ideas how to navigate around this issue when the student at the other end is on a phone or ipad/tablet?
In my situation, the issue is with the person who has the windows device only or who has the app that I mentioned above.
