Oct 4, 2024 8:49 AM UTC
Audio Issues on the Zoom App During Meetings with Edge Computing – Any Advice?
Hi everyone,
I hope you’re doing well! I’m currently experiencing audio issues while using the Zoom app during meetings, particularly in conjunction with edge computing environments. Participants often report difficulties hearing me, and I also encounter delays in audio transmission.
I’m wondering if anyone else has faced similar issues and what solutions you might recommend. Are there specific settings or configurations I should consider to improve audio quality during my Zoom meetings?
Any insights or advice would be greatly appreciated! Thank you in advance for your help!
Thanks!
Ederson
storyhubAnswer
Oct 5, 2024 5:34 AM UTC
I would recommend letting your IT people know about your experience. Delays in audio transmission is usually a bandwidth issue and edge clients can vary widely in there available bandwidth.
storyhubAnswer
Oct 11, 2024 10:08 PM UTC
Hi @jonathanjone!
Did you see the previous response from @storyhub?
Have a great day!
Oct 21, 2024 10:37 PM UTC
Hi @jonathanjone!
Given the time elapsed since we last heard from you, I've taken the liberty of marking the provided answer as the solution.
Have a fantastic day!
