AUDIO ISSUES MUSIC CUTS OUT DURING FITNESS CLASS
- 2 replies
- 162 views
- Translate
Hello, I just wanted to give a solution that worked for me after I had zero luck hearing back from Zoom and none of the previous solutions in the community worked. I have been teaching yoga on zoom for 3 years and never had a problem until my last few sessions where my clients were hearing my music cutting out (I play it live from a Bose speaker in the room) while I'm talking or even cutting out when only the music is playing. I am on a Mac with Monterey 12.6.2 - but it had nothing to do with the laptop, it is in the Zoom setting and I want to share my solution in case anyone else has this issue.... GO TO ZOOM / PREFERENCES / AUDIO / AUDIO PROFILE/ click on Zoom optimized audio BUT MOST IMPORTANT... Background Noise Suppression - CHECK THE MEDIUM BOX - and WALA!!! You can test the speaker and this worked perfectly for me, I do NOT have Original sound checked. Hope this works for you if you experience the same problem.
