Mar 29, 2022 9:35 AM UTC
Audio Issues - Microphone goes soft after a video
Hi guys,
I'm writing here to ask for help. I had audio issues the past weeks. Here are some of them:
  • Microphone is too soft; people can't hear me; when I did the audio test; part of my speech was cut off. >> resolve this by logging in-out repeatedly till it is ok.
  • My microphone/ voice was ok; but after I played a video; my voice became soft >> it goes to normal after a while.
  • I would be talking; then my voice goes really soft; and suddenly goes back to normal.
I've not made any changes during this time.
I use a wired earphones. Thank you guys in advance.
    IP-Man
    IP-ManAnswer
    Mar 29, 2022 10:15 AM UTC
    @WanTing , please try upgrading you Zoom client to the latest version and if that won't work you could try a clean removal/uninstall of Zoom Application and then reinstall it again. This is to ensure that any corrupted files/config on the application is all completely removed before reinstalling.
    If you have a Mac - try uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
    You can do this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
    After this, try to reinstall Zoom again.
    IP-Man
    IP-ManAnswer
    crchan123
    Jun 22, 2022 8:14 PM UTC
    Hi @WanTing! Has the reply posted by @IP-Man answered your question? If so, please don’t forget to mark the reply as an accepted solution 😊
