Audio issues
I am hosting a meditation and the microphone does not pick up my snaps which are needed for the process. i have a microphone , I have it on Low setting -what can i do?
    MGSRAnswer
    Hello @Nicole77
    You may follow the instructions below:
    Enable original sound during a meeting
    1. Sign in to the Zoom desktop client.
    2. Start or join a meeting.
    3. Connect to meeting audio with the Computer Audio option.
      In the top-left corner of the meeting window, the current status of the Original Sound for Musicians feature is indicated.
    4. Click the Original Sound for Musicians button to toggle this on or off.
      A notification will appear, indicating if the feature is currently enabled or not.
    Note: If you enable Original Sound for Musician in a meeting, all noise suppression is disabled. If you disable Original Sound for Musicians, the client reverts to the noise suppression setting that you chose in client settings, meaning it could be Auto, Low, Med / High.
    You can read more in this article.
    Let us know if you need further assistance.
    MGSRAnswer
    Hello @Nicole77
    Hi @Nicole77,
    Given the time elapsed since we last heard from you, I've taken the liberty of marking the provided answer as the solution.
    Have a fantastic day!
    Hi @Nicole77,
    Did you see the previous response?
    Have a great day!
