Jul 4, 2022 3:17 PM UTC
Audio echoes for participants BUT not for the host
So I've been using Zoom meetings for a long time without any issues. And then we started having problems about a week ago. I'm the host and usually I have 1 to 6 participants in a meeting. I can hear everyone absolutely fine, myself included, no echoes, nothing. However, from time to time, all the participants say that they hear echoes - echoes of their own sounds and echoes of other participants, but they hear me, the host perfectly.
Anyone ever have this problem? Any guesses what could be wrong? Any help is much appreciated, because I'm just super annoyed by now (reinstalled Zoom twice already, checked everything million times, everything seems to be working fine for me, but at the same time I know that something is not okay, because this happens again and again, in different meetings with different participants)
Jul 4, 2022 4:51 PM UTC
Ask if anyone is on speaker phone and if so ask them to take it off.  That is usually the problem.
mes10Author
Jul 5, 2022 2:12 PM UTC
Thanks for the suggestion. Unfortunately, this is not the case. The issue I have keeps happening in different meetings with different sets of participants (who are not on speaker phone).
Jan 25, 2026 12:17 AM UTC
same with me
Jul 5, 2022 4:40 AM UTC
By any chance, do you have Original Sound turned on by accident? That can cause echoing that the host cannot hear but attendees can.   Zoom support page for Original Sound
mes10Author
Jul 5, 2022 2:16 PM UTC
Thanks for the suggestion. Unfortunately this isn't the case either, original sound is not turned on, Literally, I have changed zero settings, and one day things were working fine and the next day they weren't.  I thought it could be because of a Zoom update but nobody I talked to seems to have issues like I do.
Aug 2, 2022 8:08 PM UTC
I am having this issue also - even if I am not hosting, other people get their own audio echoing, even though mine is fine.  Did you ever find anything out?
Oct 9, 2023 1:22 PM UTC
I don't see "advanced" option under audio settings... Having the same echo issue.
Jul 24, 2024 4:07 PM UTC
So the issue we have is we have the Ecamm-lookback-zoom integration and one day it just stopped working. My problem is everything on mine (host) seems fine but the participants in zoom tell me I (host) does not echo but when they speak their voice is echoing back.  I have tried everything.  Also in the recording that problem does not record, but very hard on participants during the live.  Any help please?
Aug 29, 2024 3:18 AM UTC
I am having the exact same issue. It started when I updated the Zoom application on my computer.
Aug 30, 2024 7:41 AM UTC
As an audio engineer I know that computer audio can be very complicated. Echo is a form of feedback that can also occur because of incorrect settings that are buried in the OS system. Try making sure that all mics (including the host mic) are muted and that only one mic at a time is unmuted. Go thru this with each participant to see if there is echo. Then unmute an additional mic to check for echo by having those participants speak one at a time. Be sure that ALL participants have original sound turned off. If still no echo try turning on the host mic and one other participants mic and have the participant speak to see if they hear their own voice echo. Eventually you will find the right combination that produces echo. Then those device's settings and hardware needs to be carefully examined.
Jan 25, 2026 12:00 AM UTC
I’m having the SAME problem. I can’t join from a web browser -- that seems to make it echo for everyone else and not for me. I always have to leave my own meeting to try logging in using the zoom button on the bottom of my screen. But that doesn’t always work either. This is REALLY maddening.
May 9, 2026 8:20 AM UTC
Zoom has always worked a treat, until about 3 weeks ago. Now every meeting I run, whether with one person or more, complain about a maddening echo. No matter if we mute or not, the participant/s hear the echo. We’ve tried having them turn on their Zoom and switching accounts, but it continues. So we move to WhatsApp, where everything is fine. Makes me think it’s time to discontinue my subscription which I have had for 6 years…. Hello Zoom! HELP!!!!!
May 12, 2026 8:53 PM UTC
Hello ​@Inger Lannero,
An echo that participants hear (but the host doesn’t) is almost always being caused by one attendee’s audio setup (for example, they joined audio twice, or they have speaker output feeding back into their mic).
Try this in the meeting:
  1. Identify the source
  • Have everyone mute.
  • Then unmute one participant at a time until the echo returns—whoever triggers it is the source. 1
  1. Fix it on that participant’s side (most common causes)
  • Make sure they’re connected to only one audio source (not both computer audio + phone audio). 1
  • If they’re on computer audio: use headphones, or lower speaker volume / move mic away from speakers. 1
  • If multiple devices are in the same room (two laptops, a conference room system + laptop, etc.), keep only one device unmuted.
You can read more in this article.
New Member
Aug 19, 2026 12:22 AM UTC
I am also having the same issue. When I am unmuted, everyone else echoes on their end when they talk. When I am muted, the echo goes away. When I wear headphones, the echo is also gone. I don’t have this issue on any other video app. Only zoom. And I’m obviously not the only one having the issue. I shouldn’t have to wear headphones every time I zoom in the privacy of my house.
My settings are set to computer input and computer output. Please tell us what audio settings zoom and the computer need to be on. Thank you.
Aug 19, 2026 6:12 AM UTC
This type of issue is usually related to audio feedback from one of the participants’ devices rather than the host account itself. Since the host hears everything normally but participants hear echoes of their own voices and others, it would be worth checking the participant setups.
Some common things to try are asking participants to use headphones instead of speakers, mute participants one by one to identify the source, and make sure no one is connected to the same meeting from multiple devices at the same time. Also, checking Zoom’s original sound settings, audio drivers, and updating the Zoom client may help.
Testing with a new meeting and comparing results can also help determine whether the issue is account-related or caused by a specific device or environment.
