Oct 14, 2021 8:22 PM UTC
Audio does not work correctly for me on macOS (Always uses built-in audio regardless of settings)
When I join or host a zoom meeting zoom does not use my headphones or headset but rather uses the laptop's audio.
OS: macOS 10.15.7
Zoom: 5.8.1
Permissions: Zoom has be granted all permissions in system settings security.
System audio settings: The headset
  • Input "OpenComm by AfterShokz" Type Bluetooth
  • Output "OpenComm by AfterShokz" Type Bluetooth
The headset audio works for all system audio including other meeting software.
Zoom preferences/ audio settings:
  • Speaker: "OpenComm by AfterShokz" (also tried same as system)
  • Microphone: "OpenComm by AfterShokz"
When I use the audio test, and when I am in an actual meeting, the laptop speakers are used rather than the headset.
I have no way of known which mic is being used by zoom, the headset or the built-in mic. (Both "work");
How do I get Zoom to actually use the audio that it says it is using?
    Oct 16, 2021 9:51 PM UTC
    I am facing the same issue in Windows when I am hosting meetings from my site.
    mmynstedAuthor
    Oct 17, 2021 9:41 PM UTC
    Interesting. I expected this to be specific to macOS. I have uninstalled zoom, removed all traces, including configuration files, preference, etc. then re-installed, and have the same issue as before.
    Nov 12, 2021 7:49 PM UTC
    I'm having the same problem with Windows 10 with all of my headsets even after doing the testing and it's a green from there. NO JOY no one can hear me and I sound dead in my own headset
    May 19, 2022 2:41 AM UTC
    Hey there!
    So I am using Zoom on an Apple Silicon Macbook Pro.
    I was facing this same issue, and all i did was update to the latest OS and voila! Everything works just fine.
    Best of luck comrade,
    Coolguy
    Jun 7, 2022 3:32 AM UTC
    Ages ago I had turned on "Audio Hijack", the actual name. It let me improve audio for recording etc. It was taking the audio, as I had it set up. This is what prevented the headsets from working. This was not a problem with zoom or audio hijack. It was me forgetting this was setup.
