Dec 30, 2021 10:08 PM UTC
Audio Delay, Loud Static/White Noise
My guitar teacher and I have tried using Zoom for guitar lessons but there is a significant delay in audio during our meetings. Occasionally, there is a loud prolonged noise that sounds like white noise, static or a train passing by. It is so loud that it drowns out everything else and nothing else can be heard. The audio delay is a constant problem and the loud white noise static is a frequent problem. How do I eliminate these issues? Thank you.
    rn-zmAnswer
    Jan 4, 2022 4:50 PM UTC
    Hey @StevenJM, as we do not have documentation on how to configure Zoom for Music lessons try these things:
    1. Uncheck the ‘Automatically adjust microphone volume’ so that you can control the volume of your microphone.
    2. Leave Suppress Background Noise on Auto
    3. Click the ‘Advanced’ button to access the additional audio settings and Enable Original Sound
    4. When you begin a new meeting choose ‘Join with Computer Audio’
    5. You should see a message on the top left that says “Turn On Original Sound”. Make sure you click this to enable the High Fidelity Music Mode.
    6. Ensure that original sound and stereo audio is enabled on Mobile, desktop client, and/or web client.
    Let me know if the suggested above helps! ☝️ Also, what type of microphone are you using for the input on the Zoom client?
    rn-zmAnswer
    New Member
    Jun 21, 2026 10:46 PM UTC
    I use a headset when on Zoom.  I keep getting static that occurs about 15 minutes into the meeting.  I am using a hard wired headset with a hard wired computer.  How can I eliminate this problem?
