Audio cutting out when we put microphone near piano to listen | Community
  • December 20, 2021
  • 7 replies
  • 80 views
During our Zoom church service, we switch to a mic on the piano in order to hear the music being played.  The first few notes are heard and then the audio cuts out.  When talking directly into the mic, the words can be heard on Zoom.  We have tried several mics with the same results.
We think we have adjusted the setting related to the level of background noise to allow the most noise, but it still cuts out.  Any suggestions?
Bort
I would recommend enabling Original Sound, which will disable all noise cancellation that Zoom performs. That typically works for any musicians that have their instrument removed from the meeting audio.
jsallen
Apparently there is a bug in Windows 11 that makes Zoom unusable for music. My singing teacher had the same problem on her new laptop: her talking and singing came through OK but when she hit a note on her piano, all I heard was a short thunk. If she played a scale or arpeggio,  following notes were totally silenced. No combination of settings for original sound, high-fidelity music mode, signal processing by Windows drivers and echo-cancellation resolved this problem. My teacher reverted to her old computer running Windows 10 and it works fine.
Here it is 12/18/2022 and I have the same problem. Often the first note my piano student or I play sounds like a thunk and the rest of the passage is suppressed. I have a Mac laptop.
You'd think support would have been able to figure it out in 8 months.
I love Zoom, but if this keeps up, I'll have to find another platform for my lessons.
jsallen
So now you have the problem on a Mac. My singing teacher worked around it by reverting to her older computer running Windows 10. The problem is a deal-breaker for anyone who uses a piano. Evidently, Zoom detects the straight tone (no pitch change as with a voice) and decides that it is noise. It makes a mockery of the gong used to start and end meditation sessions too. Supposed to go Ringggggggggggg... but goes Tunkk.
jsallen
My singing teacher took her computer to best Buy. Geek Squad reinstalled Windows 11. That did not solve the problem.
