Oct 20, 2022 11:32 PM UTC
Audio - Bose QuietComfort® Earbuds
I bought myself some Bose QuietComfort® Earbuds. They work on everything except Zoom. I’ve gone through all the settings I could find. And still can’t get them to work on Zoom. Any ideas?
I have a Mac laptop.
    CarlaA
    Dec 20, 2022 7:55 PM UTC
    Ji @Cyanne ! I know it has been a while since you initially posted, and I apologize for just now seeing your post! When testing on a different computer, are you able to connect the earbuds? Keep me updated!
    Carla,
    Zoom Community Team
    CyanneAuthor
    Dec 20, 2022 10:29 PM UTC
    That’s ok! I got it sorted, thanks!
    CarlaA
    Dec 20, 2022 11:08 PM UTC
    Thats great to hear! If you have some time, would you mind sharing how you were able to resolve it? I'm sure other community members with a similar question would find it very helpful!
    Jul 27, 2023 2:47 PM UTC
    I also just purchased Bose QC 2 earbuds and somehow they don't get audio from the Zoom app. However, I do get audio to the earbuds from the Zoom desktop. Other apps like Google Meet and Microsoft Teams also work fine. Somehow the Zoom app does not. And I can't find any settings in the Zoom app that allows me to select my earbuds for audio.
    @CarlaA Please advise on how to use my Bose QC 2 earbuds with the Zoom app
    Oct 10, 2025 10:08 AM UTC
    Hello everyone!
    I’ve faced the same problem recently. It turned out that Bose QC connects to a PC using two profiles: headphones and headset. For communication purposes, the headset profile should be used. Some apps may select the headset automatically, but Zoom requires manual configuration. After I selected the headset in Zoom’s audio settings, I was able to use the device for calls and meetings.
