Jun 21, 2025 1:16 PM UTC
Audio becomes silent after some minutes of Zoom Meeting in Kali Linux
Dears,
I am using Kali Linux 2025.2, the latest one, and having a  problem with this one, and I have to exit and rejoin the zoom meeting.
When I was using 2024 Kali, it was working fine.
Here is my kernel version
└─$ uname -ar
Linux 6.12.25-amd64 #1 SMP PREEMPT_DYNAMIC Kali 6.12.25-1kali1 (2025-04-30) x86_64 GNU/Linux
Please, this is irritating, please help.
Jun 25, 2025 7:41 AM UTC
Not all variations of Linux are supported - so it may work or it may not work. See the following for insights:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0063458
Also, Linux generally requires manual installation of correct dependencies. If the correct dependencies are not present the Zoom app may not function correctly. For greater stability consider using a supported version of Linux.
tj777dayAuthor
Jul 10, 2025 12:53 PM UTC
Thanks for the reply, I bookmarked that page first, but I am using zoom web version anyway, as the audio is sucks for my case now, keep switching by itself.
tj777dayAuthor
Jul 10, 2025 12:54 PM UTC
Thanks for your reply.
I am currently using Zoom web version.
I bookmarked your page and will see later, as the audio in my Linux keep switching by itself.
