Audio always cuts out with high pitches | Community
  • August 10, 2022
  • 18 replies
  • 376 views
I use Zoom to teach voice lessons, and whenever I am singing or playing higher pitches, the audio will cut out and my students can't hear anything at all. I'm wondering if anyone else has found a solution to this audio issue. Thank you!
    If youre not a big fan of the background noise removal, the web version works for me. It just lets unfiltered sound including high pitch & a pitch app based sound perfectly fine
    Unfortunately it also allows other low level irritating noises like laptop fans through that method.
