Feb 21, 2024 2:47 PM UTC
"Ask for Help" Button is not appearing in my breakout rooms
In the past, my breakout rooms had a button called "Ask for Help," which allowed students in the breakout room to request that I come see them.  That button is no longer appearing in my break out rooms.  How do I get that function back?  Thank you!
Feb 21, 2024 3:24 PM UTC
Hello @marinadelsol ,
All "attendees" will have this option as outlined here. Please have them check this:
from within the meeting controls. I hope this helps.
Feb 21, 2024 3:58 PM UTC
My attendees do not have an "ask for help" or "invite host" option.  What do I need to do so that they will be given this option?  They previously had this option.
Feb 21, 2024 5:57 PM UTC
Thank you for letting us know. If this only occurred recently, then it may have something to do with the user's device or version. It may even be potentially caused by the user's ID. Having said this, I highly recommend having the owner/admin submit a ticket to our support and include the meeting ID or any relevant information (e.g. screenshots) for a much more agile investigation.
Apr 18, 2024 2:09 PM UTC
Did anything happen with this? I just updated on 4/15/24 and no longer see Ask for Help as an option in breakout rooms.
Nov 19, 2024 1:30 PM UTC
I have exactly the same issue. Very annoying!!
Nov 19, 2024 1:28 PM UTC
I can not see the "Ask for help" icon in Breakout rooms anymore. Very annoying!!
Dec 2, 2024 7:07 PM UTC
Welcome to the Zoom Community, @Dolores1! I'm sorry for the inconvenience you experienced. Can you kindly try reinstalling the app with the latest version and let us know if the issue persists?
Feb 18, 2026 8:09 PM UTC
This Q is a year old and has no answer yet, has anyone found where the ASK for HELP button is in the Break Out Rooms? please   Thanks
New Member
Nov 9, 2026 9:04 PM UTC
I have the same question today -- November 9, 2026.
No “Ask for help” and no “Invite host”? I have the latest version of Zoom.
harrietsloane
Nov 10, 2026 7:39 AM UTC
I have seen the same thing recently, and it is frustrating when you rely on that button during a class. In my case it seemed to come and go after updates, so I now double-check the breakout room controls before the session starts. I hope Zoom brings back a clearer option for students to reach the host, because that quick request really helps keep a session running smoothly.
