Apr 7, 2026 7:22 AM UTC
Anyone using Zoom + YouTube together for webinars or live sessions? Post:
Hey, I’ve experimented with this setup a bit, so I’ll share what I’ve seen.
Streaming Zoom directly to YouTube works pretty well overall, but there’s usually a slight delay on the YouTube side (anywhere from 10–30 seconds). It’s not a huge issue for webinars, but it can feel awkward if you’re trying to interact with both Zoom attendees and YouTube viewers at the same time. Quality mostly depends on your upload speed—if your connection isn’t stable, YouTube tends to compress things more.
For sharing YouTube videos during Zoom calls, I’ve noticed the same problem. The key thing is to use “Share Screen” with the “Optimize for video clip” option and make sure system audio is enabled. Without that, playback can look choppy or audio goes out of sync.
One more thing that’s kind of interesting—viewer experience can vary depending on how people watch content. Some attendees use modified apps like YouTube Premium APK (for example, you can visit site like ytmodz), where ads are removed and playback is smoother. That can slightly change how they experience your stream compared to standard YouTube viewers, especially when it comes to interruptions and watch flow.
For webinars, I’ve found it works best to treat YouTube as the broadcast platform and Zoom as the interaction layer. Trying to balance both equally can get messy. Curious if anyone here is using OBS or another tool in between Zoom and YouTube to improve control or quality?
    Contributor I
    Apr 7, 2026 7:39 AM UTC
    Great question this setup is becoming pretty common now.
    From my experience, Zoom to YouTube streaming is generally reliable, but there’s usually a 10–20 second delay on YouTube, so real-time interaction can feel slightly off compared to Zoom. Quality is decent, but it really depends on your upload speed and Zoom’s stream settings.
    For sharing YouTube videos inside Zoom, enabling “Optimize for video clip” and sharing computer sound makes a big difference. Also, closing background apps helps avoid lag or choppy playback.
    Audience-wise, YouTube tends to be better for reach, while Zoom is stronger for interaction so it depends on your goal.
