Oct 5, 2022 3:57 PM UTC
Allow specific attendees not to have to register? Is it possible?
I have a meeting scheduled that must require registration for most attendees. However, there will be some presenters that I want to be able to just send a join link to without them having to go through the hassle of registering first. I can't find a way to make this happen. Is this possible or is there a workaround?
Many thanks for any help!
    Oct 6, 2022 4:35 PM UTC
    Hi, @Sourismom,
    Plenty of ways to do things on Zoom... some I'd recommend, others I wouldn't.
    Okay I think I misread your Email and thought you were doing a Webinar... but sounds like you're doing a meeting.
    For a meeting, you can send them the short-form Join link: us02web.zoom.us/j/111222333444 with the meeting ID at the end.  If you enable Passcodes, you'll also need to embed that in the URL.  TRY IT IN ADVANCE to make sure it will work.  Unfortunately, there's no way to register them yourself, without going through the normal registration screen, which is a pain.
    Just in case you decide on a Webinar, I'll leave this in...
    FOR A WEBINAR
    Not having them registered at all and sending them a generic Join URL makes it easy for them.  Assuming you've checked "Registration Required", all of the links you'll get from Zoom will have the form of:
    us02web.zoom.us/webinar/register/abcdefghijklmnop12345
    They'll be stuck registering, and that will only get them into the attendee view... not the panelist view.
    The better thing to do is to use the Panelist Invitation at the bottom of the web-based Webinar screen:
    Clicking Edit (far right) brings you this screen:
    You can see I've entered one panelist, and the box at the bottom is checked by default and will send the panelist their personalized link to get directly into the Panelist area.  Be sure to mention to them all, in your prep emails, not to share that Join link with anyone!!  Why?  Because everyone that joins with that link will show up as John Smith -- what you type into the Name field will become their display name in the Webinar!
    What I like to do is resend the Panelists the Join link the morning of the webinar.  Go to the Panelist Invitation area, click Edit (far right), and see this:
    If you have multiple panelists, click the RESEND button for each one, and Zoom will send another Panelist Invitation with their personal Join link embedded in it.
    That's what I'd recommend... and it's what I do when I produce webinars for others.
    SourismomAuthor
    Oct 7, 2022 4:17 PM UTC
    Thank you, Ray, I really appreciate the detailed answer. It is a meeting -- we don't have webinar capability. I tried testing the short-form meeting link as you suggested, but it still required registration.
