Allow participants to unmute themselves - option not showing in Settings
Suddenly, people can no longer unmute themselves in a meeting.  (It's SO aggravating and unprofessional when Zoom autocratically changes settings without even warning, so we get in a meeting and it's not working as expected! 🤨)
I found this answer but the setting option doesn't exist...
"This setting (Automatically mute all participants when they join the meeting) will disable all participants’ audio when they first join the meeting, i.e. they will be able to unmute themselves after joining.
"Afterwards, the host or co-host can mute all participants that are already in the meeting, as well as new participants joining the meeting.
  1. Click Participants
     located in the meeting controls.
  2. Click Mute All to mute all current and new participants.
  3. (Optional) Check Allow participants to unmute themselves if you would like participants to be able to unmute at any time during the meeting."
I can't find  Participants tab in the first place, but i do see this...
"Mute all participants when they join a meeting
Automatically mute all participants when they join the meeting. The host controls whether participants can unmute themselves."
But there's no setting anywhere i can find that says...
"Allow participants to unmute themselves"
Help!
    Thanks for reporting this issue, Zoom has just fixed the issue, please test again. Let us know if you have other problems, your voice is important to us.
    It works now!!
    I’m very surprise that our comments/feedback was taken seriously. I really appreciate that you took care so efficiently, thank you
    Yes, our issue fixed thank you very  much!
    zoome1Author
    The issue has NOT been fixed...
    Even though my settings are to "mute all participants when joining", new participants are UNmuted.
    Something's still wonky.
    Hi, I believe the issue "people can not unmute themselves" is fixed, and you mentioned a new issue.
    Please know the setting "Mute all participants when they join a meeting" needs to be used with the advanced option "Mute participants upon entry" when scheduling a meeting, and this setting does not work for instant meetings.
    If you still have this issue with the option "Mute participants upon entry" checked for scheduled meetings, please submit a ticket and we will investigate it in detail.
    Thanks!
