AI companion - problems | Community
  • November 22, 2023
  • 29 views
Can I change the language in the administrator?, I have problems with summaries, Im confused becouse there are very bad . Please help
Bort
Hi @Ivalejo
The generation of the Meeting Summary is based on the speaking language you have set for yourself during the meeting. Please make sure your speaking language is set correctly so that the transcript is accurate and the summary makes sense.
Hope that helps and let me know if you have any further questions. Otherwise, make sure to mark the solution as accepted if this information is what you needed.
