2 audio sources input | Community
  • November 7, 2023
  • 28 views
Hello, I want to use 2 audio sources input (2 differents microphones) on a laptop. The option "Use specific audio input channels" as described in Zoom support note doesn't appear, so I use only 1 mic at the same time.
For information, I have 4 audio sources connect, 2 mic, 1 built in sound device and one other.
My desktop version client i 5.16.2 (22807)
How can I solve my issue ?
Thanks
bstrelko
Unfortunately, this feature only applies to single audio devices with at least 3 audio channels connected (multiple devices not supported, only multi-channel audio on one device).
More info can be found here:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057961
An aggregate audio device (ASIO4ALL would be the one for Windows) might help you work around these limitations, but it is extremely picky and does require a bit of digital audio tech know-how.
Please submit a feature request to Zoom via Zoom Support to make sure your needs are on their radar!
Thanks so much for your quick answer
