Jun 5, 2025 6:05 PM UTC
Meeting audio only works when zoom audio setting window is open
Without changing anything, one day this started happening. I am connected to computer audio as usual. And the laptop's speaker is chosen but I can't hear anything. I open the audio settings to test the speaker and before even clicking on it suddenly I can hear the speaker. I test the speaker (same laptop speaker) and can hear the chime. Great. Close the window and can no longer hear the speaker. So now I have the window open the entire meeting to be able to hear while I try to figure this out. Help!
    Jun 6, 2025 10:17 AM UTC
    That’s definitely unusual behavior it sounds like Zoom may not be maintaining the correct audio routing unless the settings window is open, which could indicate a software glitch or driver conflict. I’d suggest first updating or reinstalling your audio drivers, and also try resetting Zoom's audio settings under Settings > Audio > Advanced > Restore Defaults. If that doesn’t help, reinstalling Zoom or testing with a different audio output device (like headphones) might narrow down the issue. Definitely worth reporting to Zoom support if it persists
    DanieMcDeAuthor
    Aug 19, 2025 7:19 PM UTC
    Thank you for responding. I was using a Bluetooth speaker for sound for a little while then that stopped working too. New IT guys pushed a bunch of update commands on my computer (beyond zoom/normal updates you get notified about) and it works now.
    Jun 24, 2025 8:01 PM UTC
    This is happening to me too - did you ever figure it out? It's driving me crazy.
    DanieMcDeAuthor
    Aug 4, 2025 3:41 PM UTC
    Company IT couldn't figure it out either 😩
    Jul 29, 2025 7:43 PM UTC
    for me unplugging and plugging dongle worked as this was happening with wireless headphones for me.
    DanieMcDeAuthor
    Appreciate the response. I don't have any headphones/devices connected just the laptop by itself is doing this.
    Aug 19, 2025 7:12 PM UTC
    This is happening to me too, except it is happening with a wireless headset. I'm at work and my firm Tech Help feels this is user error. Hoping something pops up here that can help.
    DanieMcDeAuthor
    Aug 19, 2025 7:20 PM UTC
    New IT guy (#3) pushed a bunch of update commands on my computer (beyond zoom/normal updates you get notified about) and it works now.
    Nov 13, 2025 4:09 PM UTC
    I’ve been experiencing the same issue for weeks. I uninstalled and reinstalled Zoom, but the problem persists. It only occurs during webinars and with my bluetooth headset; my regular meetings work perfectly fine. The setting must remain on the audio subtab; if I switch to another one, the audio disappears again. So strange! Your post definitely deserves more likes!
    Nov 20, 2025 7:51 PM UTC
    Hello @NetSuite,
    If your meeting audio only works when the Zoom audio settings window is open, this could indicate an issue with your audio device selection or a conflict with your system’s audio drivers. Here are some steps you can try to resolve the issue:
    1. Check Audio Device Selection:
    • In Zoom, click the arrow next to the microphone icon and make sure the correct microphone and speaker are selected.
    • Test both your microphone and speaker in the Zoom audio settings.
    1. Update Audio Drivers:
    • Make sure your computer’s audio drivers are up to date. Outdated drivers can cause audio issues.
    1. Restart Zoom and Your Computer:
    • Close Zoom completely and restart your computer to clear any temporary glitches.
    1. Disable Exclusive Mode (Windows):
    • Go to Control Panel > Sound > Playback tab.
    • Select your speaker, click Properties, then the Advanced tab.
    • Uncheck “Allow applications to take exclusive control of this device.”
    1. Check for Conflicting Applications:
    • Make sure no other applications are using your microphone or speakers at the same time as Zoom.
    1. Reinstall Zoom:
    • Uninstall Zoom, restart your computer, and reinstall the latest version from the official Zoom website.
    Let us know if it helps or if you need further assistance.
