Power point slides not displaying properly | Community
  • February 3, 2022
  • 73 views
Hi there. I have been using power point to teach online with zoom for quite sometime now and I have started to run into  the following issue: My students are saying that the bottom end of the slides, when I am using the full screen presentation mode, are not displaying correctly. Basically anything that it is near or at the lower end of the slide is cut off and they are not able to read. Anyone has had this issue? I have toyed with PP and zoom setups to no avail.
Thanks in advance.
Marcio
    Hello, sounds like a scaling problem, have you tried different resolution settings to help with this? Have you tried sharing content on the PPT application specifically or are you sharing the entire desktop?
