No sound for participants when sharing audio from I-Phone
I would like to share sound of a language app or I-Tunes on my I-Phone. My students can not hear the sound from the I-Phone, but can hear the sound when playing a video that is shared from the Internet.
I click on share screen and always enable share sound before I connect with Airplay, just as described in the tutorial.
It worked in the past, but since the last four weeks or so it does work anymore.
Thanks for your suggestions.
    kbrewer
    In the situation where it was recently working but isn't now, I almost always find that the issue is resolved once the user updates their Zoom client on the device. so I would check to make sure that your client is up to date. Also I wonder if connecting your phone to your computer with a physical cable may do the trick.
