Sep 18, 2026 2:21 AM UTC
Clips Using Noise Cancelling Even When Disabled
Use Case:
I am a student musician. I need to record myself playing instruments over backing tracks that are provided by the instructor. PC audio is piped into the aux channel of an amplifier that the instrument is also plugged into. The combined signal is recorded through a high quality studio microphone positioned in front of the amplifier, close to the grille.
Zoom Version Number: 7.1.8
Steps Taken:
I have double checked all of the settings. I’ve check the input level of the mic, the output level of the amp. When I record in Clips, it sounds completely useless, with the majority of the signal dropping out. I have ensured that:
  1. Original sound for musicians is enabled in settings.
  2. High-Fidelity Music Mode is enabled in settings.
  3. Echo Cancellation is disabled in settings
  4. Under the Advanced tab:
    1. Echo cancellation is set to Auto (it cannot be turned off on this screen)
    2. Windows System Audio Enhancements is disabled
    3. Signal processing by Windows audio device drivers is disabled
  5. When starting a Clips recording, I have confirmed that:
    1. The correct microphone and speaker are selected
    2. Under Advanced Settings, Noise Suppression is disabled
Why I believe this is a new problem with Clips:
  1. I used Clips earlier this year extensively for the same purpose without issue. This is a new problem.
  2. When I record from the full meeting window with all the same hardware and settings, the audio recording is fine. The issue is in Clips.
Why I believe this is an issue for me:
  1. The literal ENTIRE reason I upgraded to Premium is for Clips, to make extemporaneous recordings with effectively a one-click interface. Its purpose was to replace Dolby ON.
  2. Clips worked for months for my use case. I never had a problem through May 2026. It’s a new semester.
  3. Clips has an option to disable noise suppression, and it is not working as advertised.
Steps to Reproduce:
  1. Set up Clips as describe above, both in the main Settings screen, and the settings of the individual recording popup for a new Clip.
  2. Position a microphone in front of your PC speakers.
  3. Play an audio clip, a song, a beat, whatever you like.
  4. Notice on playback that you hear roughly a tenth of what’s being played.
  5. Delete the clip and start a new meeting.
  6. Do nothing else, but go into the More (...) button and press Record.
  7. Play an audio clip, a song, whatever, through the same PC speakers.
  8. Stop the meeting and wait for it to process.
  9. Go into your recorded meetings location and play the video and/or audio. Notice that there is no dropout, no noise cancelling.
jrmagno
Oct 1, 2026 3:38 PM UTC
Thank you for providing such detailed information and for clearly documenting the steps you’ve taken. I understand how important Clips is to your workflow, particularly since you upgraded specifically to use it for recording instruments with backing tracks.
Based on your testing, the issue appears to be isolated to Clips, since the same microphone, hardware, and audio configuration work correctly when recording through a regular Zoom meeting.
The fact that you have already enabled Original Sound for Musicians and High-Fidelity Music Mode, disabled noise suppression and echo cancellation, and confirmed the issue persists also suggests that the audio processing in Clips may not be behaving as expected.
At this point, I recommend escalating this to Zoom Support for further investigation. Please include the Clips recording examples, Zoom version (7.1.8), operating system, and the detailed reproduction steps you provided. These will help the engineering team compare Clips' audio processing with regular meeting recording.
As a temporary workaround, you can continue using a regular Zoom meeting recording, since you confirmed that this produces the expected audio quality.
Thank you again for documenting the behavior so thoroughly. Your comparison between Clips and regular meeting recording is particularly useful and should help with troubleshooting and identifying whether there is a regression in Clips.
