Apr 22, 2022 8:59 PM UTC
Bluetooth speaker volume control not working on pc
No text available
    Apr 22, 2022 9:23 PM UTC
    Not enough information to help you. Might be a Windows problem?
     What other speakers have you used successfully? Has the Bluetooth speaker worked on other apps? Is the speaker not producing any sound at all, or are you just unable to raise and lower the volume?
    alex65Author
    Apr 22, 2022 10:17 PM UTC
    The speaker is a BOSE Bluetooth.  Works fine on all other apps i've used (YouTube, etc.).
    Sound comes out fine but the volume control on the speaker (+/-) does nothing.  I have 2 use the volume control on the task bar.
    THANKS 4 your help.
    Apr 22, 2022 10:29 PM UTC
    So I'm still a little unclear... if you need to use the volume control on the task bar, is it not available to you when using Zoom?  Or it's available but moving it doesn't change the volume?
    If you're using Windows 10, click on the volume control in the task bar and select the Volume Mixer from the pop-up menu:
    here:
    then here:
    In the volume mixer, locate your Bluetooth speaker, and you should be able to adjust the volume of the speaker (and of the individual apps) there as well.
    Hopefully that gets you closer to a solution, @alex65
    alex65Author
    Apr 22, 2022 10:43 PM UTC
    Clarification:
    The sound from the Bluetooth speaker works just fine. But the volume control does not work at all when using Zoom.
    I have 2 use the task bar volume control to adjust the volume.
    That's the issue.
